Ana içeriğe geç
DeWalt DW235G Drill Chuck Part Replacement
Neye ihtiyacın var
  1. DeWalt DW235G Drill Chuck Part Replacement, Chuck Component: adım 1, 1 resimden 1.
    • Identify the Hex nut within the inside of the chuck of the drill.
    • Insert the 4mm Allen key into the chuck to loosen the Hex nut.
    • The Hex nut is reversed threaded. To loosen the nut, simply twist the 4mm Allen key in the opposite direction.
  2. DeWalt DW235G Drill Chuck Part Replacement: adım 2, 1 resimden 1.
    • Re-insert the 4mm Allen key into the chuck after the Hex nut has been taken out.
    • Make sure that the 4mm Allen key is firmly in place inside the chuck.
  3. DeWalt DW235G Drill Chuck Part Replacement: adım 3, 1 resimden 1.
    • Using a hammer or blunt object, strike the 4mm Allen key in order to break loose the chuck from the body of the drill.
    • Make sure the drill is thoroughly secured before striking.
Sonuç
To actually install the chuck replacement part, follow the guide in reverse order.
Bir başkası bu kılavuzu tamamladı.
Adam V
166 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 77
Son 30 gün: 230
Her zaman: 1,323
