Ana içeriğe geç
DeWalt DW660 Motor Brushes Replacement
Neye ihtiyacın var
  1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: adım 1, 2 resimden 1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: adım 1, 2 resimden 2.
    • Remove the four 19mm T20 Torx screws at the rear of the device.
  2. DeWalt DW660 Motor Brushes Replacement: adım 2, 3 resimden 1. DeWalt DW660 Motor Brushes Replacement: adım 2, 3 resimden 2. DeWalt DW660 Motor Brushes Replacement: adım 2, 3 resimden 3.
    • Remove the other part of the back casing.
    • Unplug the black and white power wires from the motor.
  3. DeWalt DW660 Motor Brushes Replacement: adım 3, 2 resimden 1. DeWalt DW660 Motor Brushes Replacement: adım 3, 2 resimden 2.
    • Pinch the blue brush wire between two fingers.
    • Pull on the wire, removing them from the motor.
  4. DeWalt DW660 Motor Brushes Replacement: adım 4, 2 resimden 1. DeWalt DW660 Motor Brushes Replacement: adım 4, 2 resimden 2.
    • Using the metal spudger, lift up the coil spring that holds the carbon brushes in place.
    • While the spring is lifted up, remove the carbon brush by simply sliding it out of the slot.
  5. DeWalt DW660 Motor Brushes Replacement: adım 5, 2 resimden 1. DeWalt DW660 Motor Brushes Replacement: adım 5, 2 resimden 2.
    • Repeat steps 3 and 4 to remove the other carbon brush.
    • When installing the new carbon brushes, make sure each brushes' lead wire is plugged into opposite ends of the motor.
    • Refer to the photos for visual assistance.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joseph Pacitto
239 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Isaacson Spring 2016 UMass Dartmouth, Team 2-7, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G7
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,429
