Giriş
The power cord can simply be replaced by opening the back of the device and unscrewing the casing. Make sure that the device is not plugged in before working on it.
Neye ihtiyacın var
Using a T20 Torx Screwdriver, unscrew the four 19mm screws from the back casing.
After unscrewing, remove the back casing from the device.
Bir başkası bu kılavuzu tamamladı.
