Ana içeriğe geç
DeWalt DW920 Lock Switch Replacement
Neye ihtiyacın var
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: adım 1, 1 resimden 1.
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: adım 2, 1 resimden 1.
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: adım 3, 1 resimden 1.
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: adım 4, 1 resimden 1.
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: adım 5, 2 resimden 1. DeWalt DW920 Lock Switch Replacement: adım 5, 2 resimden 2.
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
Sonuç
Stephen Rada
433 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G2
2 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
This guide was descriptive and easy to follow. Good job!
DankMemerino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 286
