Ana içeriğe geç
DeWalt DW920 Motor Replacement
Neye ihtiyacın var
  1. DeWalt DW920 Motor Replacement, Disassembly: adım 1, 1 resimden 1.
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: adım 2, 1 resimden 1.
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: adım 3, 1 resimden 1.
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: adım 4, 1 resimden 1.
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: adım 5, 1 resimden 1.
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: adım 6, 1 resimden 1.
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
Sonuç
Stephen Rada
433 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G2
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 828
