Ana içeriğe geç
DeWalt DW920 Rotational Switch Replacement
Neye ihtiyacın var
  1. DeWalt DW920 Rotational Switch Replacement, Disassembly: adım 1, 1 resimden 1.
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Rotational Switch Replacement: adım 2, 1 resimden 1.
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Rotational Switch Replacement: adım 3, 1 resimden 1.
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Rotational Switch Replacement, Rotational Switch: adım 4, 1 resimden 1.
    • Locate the rotational switch
  5. DeWalt DW920 Rotational Switch Replacement: adım 5, 1 resimden 1.
    • Carefully release the connection between the rotational switch and the motor assembly. This should be done carefully to ensure that the switch connection switch on the assembly is not damaged.
  6. DeWalt DW920 Rotational Switch Replacement: adım 6, 1 resimden 1.
    • Once the switch is freed from the assembly, firmly grip it between two fingers and lift it straight out of the drill frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cameron MacKinnon
241 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G2
2 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Everything looks good on this guide, good job!
DankMemerino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,389
