Ana içeriğe geç
DeWalt DW936 Boot Replacement
Neye ihtiyacın var
  1. DeWalt DW936 Boot Replacement, Plastic Cover: adım 1, 1 resimden 1.
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Boot Replacement: adım 2, 1 resimden 1.
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Boot Replacement: adım 3, 1 resimden 1.
    • Remove Allen Key.
  4. DeWalt DW936 Boot Replacement: adım 4, 1 resimden 1.
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Boot Replacement: adım 5, 1 resimden 1.
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Boot Replacement: adım 6, 1 resimden 1.
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Boot Replacement, Boot: adım 7, 1 resimden 1.
    • Use a T-15 hex head screw to unscrew the four screws located around the outside of the motor.
  8. DeWalt DW936 Boot Replacement: adım 8, 1 resimden 1.
    • Using an H 4.0 hex head screw, unscrew the bolt located right above the boot that is next to the motor of the saw.
  9. DeWalt DW936 Boot Replacement: adım 9, 1 resimden 1.
    • Pull the blade away from the body of the saw causing the blade and boot to detach.
  10. DeWalt DW936 Boot Replacement: adım 10, 1 resimden 1.
    • Pull the boot downwards away from the blade to detach it.
Sonuç
Scott Weinhardt
603 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-2, Banghart Winter 2017 Cal Poly, Team 8-2, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 441
