Ana içeriğe geç
DeWalt DW938 Switch VSR Replacement
Neye ihtiyacın var
  1. DeWalt DW938 Switch VSR Replacement, Clam Shell: adım 1, 3 resimden 1. DeWalt DW938 Switch VSR Replacement, Clam Shell: adım 1, 3 resimden 2. DeWalt DW938 Switch VSR Replacement, Clam Shell: adım 1, 3 resimden 3.
    • Use a torque bit screw driver to remove the T10 18.3 mm screw on the handle.
    • Use a torque bit screw driver to remove 6 T10 21.5 mm screws on the handle.
    • Insure power source is removed from tool.
    • Insure blade is removed from tool.
  2. DeWalt DW938 Switch VSR Replacement: adım 2, 1 resimden 1.
    • Carefully cut the safety sticker with a blade along the seam.
  3. DeWalt DW938 Switch VSR Replacement: adım 3, 1 resimden 1.
    • Remove the Clam Shell from the handle unit.
  4. DeWalt DW938 Switch VSR Replacement, Switch VSR: adım 4, 1 resimden 1.
    • Lift the mechanical device off the pins of the clam shell.
  5. DeWalt DW938 Switch VSR Replacement: adım 5, 2 resimden 1. DeWalt DW938 Switch VSR Replacement: adım 5, 2 resimden 2.
    • Remove the red and black trigger wires from the brush leads with the pliers.
  6. DeWalt DW938 Switch VSR Replacement: adım 6, 2 resimden 1. DeWalt DW938 Switch VSR Replacement: adım 6, 2 resimden 2.
    • Remove the VSR trigger and the lock button.
Sonuç
Christopher Chin
316 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Baechle Spring 2017 IUPUI, Team S4-G4, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S4G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 580
