Ana içeriğe geç
DeWalt DW997 Motor Replacement
Neye ihtiyacın var
  1. DeWalt DW997 Motor Replacement, Speed Switch: adım 1, 2 resimden 1. DeWalt DW997 Motor Replacement, Speed Switch: adım 1, 2 resimden 2.
    • Remove seven 21 mm Torx T15 screws.
    • Remove one 18 mm Torx T10 screw.
    • After removing all screws, lift up the top yellow cover.
    • The yellow cover should easily lift up, if not, check for unscrewed screws.
    • Do not pry the two yellow covers apart, they can crack.
  2. DeWalt DW997 Motor Replacement: adım 2, 1 resimden 1.
    • Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
  3. DeWalt DW997 Motor Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the tweezers, grab the metal leg on either side of the switch and lift it outwards from the case.
  4. DeWalt DW997 Motor Replacement: adım 4, 1 resimden 1.
    • Remove the other leg manually, it should easily come out.
  5. DeWalt DW997 Motor Replacement, Motor: adım 5, 2 resimden 1. DeWalt DW997 Motor Replacement, Motor: adım 5, 2 resimden 2.
    • Use a Torx T10 screw bit to remove the four 11mm screws around the motor.
  6. DeWalt DW997 Motor Replacement: adım 6, 2 resimden 1. DeWalt DW997 Motor Replacement: adım 6, 2 resimden 2.
    • Pull off the two wires that connect the motor to the trigger.
    • Be careful while pulling the wires as they can tear.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin
140 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 2,370
