Ana içeriğe geç
DeWalt DW997 Trigger Replacement
Neye ihtiyacın var
  1. DeWalt DW997 Trigger Replacement, Trigger: adım 1, 2 resimden 1. DeWalt DW997 Trigger Replacement, Trigger: adım 1, 2 resimden 2.
    • First remove the seven 21mm screws using a Torx T15 screw bit.
    • Then use a Torx T10 screw bit to remove the remaining 18mm screw.
    • After removing all of the screws, lift the cover off.
    • Do not attempt to pry the covers apart; doing so can cause the covers to crack.
  2. DeWalt DW997 Trigger Replacement: adım 2, 1 resimden 1.
    • Carefully remove the trigger pack by lifting the pack straight up.
  3. DeWalt DW997 Trigger Replacement: adım 3, 1 resimden 1.
    • The final step is to pull the wires off of the trigger by pulling the wire heads.
    • Be careful while taking off the wires as they can tear.
Sonuç
Bir Yorum
We supply best replacement Dewalt power tool batteries at a wholesale price in Australia. Cordless drill batteries for Dewalt are producted with high test safe circle and chips that give different capacities. We pormise the replacement Dewalt batteries are 100% compatible with the orginal porducts. Full 1 year quality assurance & 30 days money back gurantee! Select cheap Dewalt cordless drill battery by models at http://www.drill-battery-au.com/bestbatt...
drillbatterycomau - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,882
