Ana içeriğe geç
DeWalt DWD112 Power Cord Replacement
Neye ihtiyacın var
  1. DeWalt DWD112 Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Remove seven TR20 Torx Security screws from the side of the drill.
  2. DeWalt DWD112 Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove the top cover to reveal the inside of the drill.
    • Set the top cover of the drill aside.
  3. DeWalt DWD112 Power Cord Replacement: adım 3, 1 resimden 1.
    • The power cord and the trigger act as a single part and must be replaced together.
    • Using one hand grab the trigger box and with the other grab the end of the wire connecting to the trigger box and disconnect the wire.
  4. DeWalt DWD112 Power Cord Replacement: adım 4, 1 resimden 1.
    • Disconnect the second connected wire from the top of the trigger box.
  5. DeWalt DWD112 Power Cord Replacement: adım 5, 1 resimden 1.
    • Lift the trigger box up to reveal the bottom side.
    • Disconnect the first connected wire from the bottom of the trigger box.
  6. DeWalt DWD112 Power Cord Replacement: adım 6, 1 resimden 1.
    • Disconnect the last wire from the trigger box using the same method from the previous step.
  7. DeWalt DWD112 Power Cord Replacement: adım 7, 1 resimden 1.
    • After all four wires are disconnected, the trigger and power cord are separated from the drill.
    • The power cord and trigger can be set aside if further disassembly is required.
Sonuç
Samantha McSweeney
407 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Isaacson Spring 2016 UMass Dartmouth, Team 2-3, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G3
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 1,330
