Ana içeriğe geç
DeWalt DWE305 Trigger Assembly Replacement
Neye ihtiyacın var
  1. DeWalt DWE305 Trigger Assembly Replacement, Trigger Assembly: adım 1, 1 resimden 1.
    • Remove the seven 3/4" Button Head Torx Security screws out of the handle with the Torx T20H bit and IFixit Precision Bit Driver.
  2. DeWalt DWE305 Trigger Assembly Replacement: adım 2, 1 resimden 1.
    • Take the top cover off after the screws have been removed to access the trigger assembly.
  3. DeWalt DWE305 Trigger Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the single 3/4" Button Head Torx Security screw that is securing the trigger assembly using the Torx T15H bit.
    • Pull the entire trigger assembly from the handle.
  4. DeWalt DWE305 Trigger Assembly Replacement: adım 4, 1 resimden 1.
    • Use the pointed end of the metal sludger to pry open the rectangular casing that houses the electrical contacts and wiring of the trigger assembly.
    • Be very careful not to damage any of the wiring or electrical contacts with the metal spudger
    • Assess the condition of the assembly by checking the inside of the casing for any dust, dirt, or misalignment.
  5. DeWalt DWE305 Trigger Assembly Replacement: adım 5, 1 resimden 1.
    • Look on the back of the assembly by turning it over to the casing where the wires protrude and see if there is any damage to the cables which are connected to the motor assembly.
  6. DeWalt DWE305 Trigger Assembly Replacement: adım 6, 1 resimden 1.
    • Look over the spring component and see if it is misaligned or warped.
    • You may have to use the flat, blunt part of the metal spudger to move the spring around and see the inside of the casing.
  7. DeWalt DWE305 Trigger Assembly Replacement: adım 7, 1 resimden 1.
    • If any part of the trigger assembly such as electrical contacts, wiring, or the spring is damaged beyond repair, then replace the assembly and reconnect the new component to the wiring attached from the motor assembly.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 855
