Ana içeriğe geç
DeWalt DWE4011 Brush Spring Replacement
Neye ihtiyacın var
  1. DeWalt DWE4011 Brush Spring Replacement, Brush Spring: adım 1, 1 resimden 1.
    • Turn to the bottom of the device and remove the 5/8" (17mm) screw shown using a T15 Torx Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. DeWalt DWE4011 Brush Spring Replacement: adım 2, 1 resimden 1.
    • Remove outer casing by pulling the end handle away from the field case.
    FixBot'a Sor
    Yorum Ekle
  3. DeWalt DWE4011 Brush Spring Replacement: adım 3, 1 resimden 1.
    • Locate the brush springs on either side of the device.
    FixBot'a Sor
    Yorum Ekle
  4. DeWalt DWE4011 Brush Spring Replacement: adım 4, 1 resimden 1.
    • Using an iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
    FixBot'a Sor
    Yorum Ekle
  5. DeWalt DWE4011 Brush Spring Replacement: adım 5, 1 resimden 1.
    • Remove the spring by sliding it out of the center post (use an iFixit opening tool if needed).
    • When replacing the spring you need to tension it. Watch this video at 1:55 to see how.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 1,730
