Ana içeriğe geç
DeWalt DWE4011 Carbon Brushes Replacement
Neye ihtiyacın var
  1. DeWalt DWE4011 Carbon Brushes Replacement, Carbon Brushes: adım 1, 1 resimden 1.
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Carbon Brushes Replacement: adım 2, 1 resimden 1.
    • Remove the outer casing to expose the brushes by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Carbon Brushes Replacement: adım 3, 2 resimden 1. DeWalt DWE4011 Carbon Brushes Replacement: adım 3, 2 resimden 2.
    • Locate both carbon brushes on either side of the device.
  4. DeWalt DWE4011 Carbon Brushes Replacement: adım 4, 1 resimden 1.
    • Using the iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Carbon Brushes Replacement: adım 5, 1 resimden 1.
    • Keeping a tight hold the entire time, move the spring covering the carbon brush so that it is behind the male terminal.
    • Be extremely careful, as the spring is tightly coiled and can easily get away from you.
  6. DeWalt DWE4011 Carbon Brushes Replacement: adım 6, 2 resimden 1. DeWalt DWE4011 Carbon Brushes Replacement: adım 6, 2 resimden 2.
    • Taking hold of the wire you removed in step 4, gently slide the carbon brush out of its casing and remove it from the device.
    • Flip over the device to reveal the second carbon brush, and repeat steps 4 through 6 on the other side.
Sonuç
Congratulations! To put your device back together, simply reverse the above steps.
Kiera Sloan
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 1,297
