Ana içeriğe geç
DeWalt DWE4011 Power Switch Replacement
Neye ihtiyacın var
  1. DeWalt DWE4011 Power Switch Replacement, Power Switch: adım 1, 1 resimden 1.
    • Turn to the bottom of the device and remove the 1 1/4" screw shown using a T15 Torx Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. DeWalt DWE4011 Power Switch Replacement: adım 2, 1 resimden 1.
    • Remove the outer casing by pulling the end handle away from the field case.
    FixBot'a Sor
    Yorum Ekle
  3. DeWalt DWE4011 Power Switch Replacement: adım 3, 1 resimden 1.
    • Unscrew the pin that is holding the main power cord in place and remove the cord.
    FixBot'a Sor
    Yorum Ekle
  4. DeWalt DWE4011 Power Switch Replacement: adım 4, 2 resimden 1. DeWalt DWE4011 Power Switch Replacement: adım 4, 2 resimden 2.
    • Pull back the tab holding the switch box in place using a nylon spudger. There is one on top and bottom shown in the image.
    FixBot'a Sor
    Yorum Ekle
  5. DeWalt DWE4011 Power Switch Replacement: adım 5, 1 resimden 1.
    • Remove the switch box entirely from its normal position. Gently pull off the connections from the switch box to the motor.
    FixBot'a Sor
    Yorum Ekle
  6. DeWalt DWE4011 Power Switch Replacement: adım 6, 2 resimden 1. DeWalt DWE4011 Power Switch Replacement: adım 6, 2 resimden 2.
    • Using a small Phillips head screwdriver, remove the screws that hold the white colored wires from the power cord in place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 65
Her zaman: 2,093
