Ana içeriğe geç
DeWalt_D26451 Brake Replacement
Neye ihtiyacın var
  1. DeWalt_D26451 Brake Replacement, Pad: adım 1, 3 resimden 1. DeWalt_D26451 Brake Replacement, Pad: adım 1, 3 resimden 2. DeWalt_D26451 Brake Replacement, Pad: adım 1, 3 resimden 3.
    • Please wear safety glasses while completing this replacement guide.
    • Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
    • Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
  2. DeWalt_D26451 Brake Replacement: adım 2, 2 resimden 1. DeWalt_D26451 Brake Replacement: adım 2, 2 resimden 2.
    • Turn the disc pad over and remove the loosened screws.
    • When the screws are removed, the disc pad will come off of the sander.
  3. DeWalt_D26451 Brake Replacement, Brake: adım 3, 1 resimden 1.
    • Please wear safety glasses while completing this repair guide.
    • Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
  4. DeWalt_D26451 Brake Replacement: adım 4, 1 resimden 1.
    • After the T20 torx bolts have been removed, remove the disc pad from the sander.
  5. DeWalt_D26451 Brake Replacement: adım 5, 1 resimden 1.
    • When the disc pad is removed, the brake is located directly under it. Remove the brake from the sander.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 2,050
