Ana içeriğe geç
Definitive Technology W7 Motherboard Replacement
Neye ihtiyacın var
  1. Definitive Technology W7 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Definitive Technology W7 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Definitive Technology W7 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
    • The screw next to the I/O panel will be approximately 20 mm in length. The other screws will be approximately 35 mm in length.
    • Use the metal spudger to remove all rubber feet.
    • Unscrew all four screws from under the rubber feet.
    • These screws will be approximately 35 mm in length.
    • You can now use the prying tool to pry the bottom panel off the speaker.
  2. Definitive Technology W7 Motherboard Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the 5 screws from the motherboard.
    • These screws are approximately 8 mm in length.
  3. Definitive Technology W7 Motherboard Replacement: adım 3, 2 resimden 1. Definitive Technology W7 Motherboard Replacement: adım 3, 2 resimden 2.
    • Push up the locking tabs on the sides of the ribbon cable connector.
    • Gently pull the ribbon cable out from the connector to remove it.
  4. Definitive Technology W7 Motherboard Replacement: adım 4, 2 resimden 1. Definitive Technology W7 Motherboard Replacement: adım 4, 2 resimden 2.
    • Tilt the motherboard outwards from the speaker.
    • Remove all five connectors from the motherboard.
    • Remove the motherboard from the speaker.
  5. Definitive Technology W7 Motherboard Replacement: adım 5, 2 resimden 1. Definitive Technology W7 Motherboard Replacement: adım 5, 2 resimden 2.
    • Using the Phillips #2 screwdriver, remove the three screws from the network card.
    • These screws are approximately 8mm in length.
    • Remove the network card from the motherboard.
Sonuç
Magnus Maillet
171 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Petersen Fall 2022 UMass Dartmouth, Team 2-5, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 562
