Ana içeriğe geç
Dell Inspiron 15-7569 Battery Replacement
Neye ihtiyacın var
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: adım 1, 3 resimden 1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: adım 1, 3 resimden 2. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: adım 2, 3 resimden 1. Dell   Inspiron  15-7569 Battery Replacement, Battery: adım 2, 3 resimden 2. Dell   Inspiron  15-7569 Battery Replacement, Battery: adım 2, 3 resimden 3.
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Matthew Clements
546 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G4, Walkup Fall 2017 USF Tampa, Team S5-G4, Walkup Fall 2017 üyesi
USFT-WALKUP-F17S5G4
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 6,277
