Giriş
The wiring of your motherboard may have been disconnected causing the screen o not function properly. This guide will help you fix that.
Neye ihtiyacın var
Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
After removing the screws, remove the back cover using a plastic or metal spudger.
Unscrew the (6) six black screws outlined using a Phillips #0 screwdriver.
Unscrew (4) screws securing the fan using a Phillips #0 head screwdriver.
Remove the fan from the motherboard.
