Ana içeriğe geç
Dell Inspiron 15-7569 Motherboard Replacement
Neye ihtiyacın var
  1. Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: adım 2, 3 resimden 1. Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: adım 2, 3 resimden 2. Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: adım 2, 3 resimden 3.
    • Unscrew the (6) six black screws outlined using a Phillips #0 screwdriver.
    • Unscrew (4) screws securing the fan using a Phillips #0 head screwdriver.
    • Remove the fan from the motherboard.
  3. Dell   Inspiron  15-7569 Motherboard Replacement: adım 3, 3 resimden 1. Dell   Inspiron  15-7569 Motherboard Replacement: adım 3, 3 resimden 2. Dell   Inspiron  15-7569 Motherboard Replacement: adım 3, 3 resimden 3.
    • Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires.
    • Remove the black speaker wire.
    • Remove the white display wire.
  4. Dell   Inspiron  15-7569 Motherboard Replacement: adım 4, 3 resimden 1. Dell   Inspiron  15-7569 Motherboard Replacement: adım 4, 3 resimden 2. Dell   Inspiron  15-7569 Motherboard Replacement: adım 4, 3 resimden 3.
    • (Continued)Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires
    • Remove the gold and silver display cables.
    • Remove the white fan cable.
    • Remove the USB-to-motherboard cable
  5. Dell   Inspiron  15-7569 Motherboard Replacement: adım 5, 2 resimden 1. Dell   Inspiron  15-7569 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the black battery cable.
    • Remove the blue ribbon cable.
    • Unscrew and remove hard drive/SSD.
    • Disconnect the hard drive/SSD from the motherboard.
  6. Dell   Inspiron  15-7569 Motherboard Replacement: adım 6, 2 resimden 1. Dell   Inspiron  15-7569 Motherboard Replacement: adım 6, 2 resimden 2.
    • Gently remove the motherboard from the device.
Sonuç
Matthew Clements
546 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G4, Walkup Fall 2017 USF Tampa, Team S5-G4, Walkup Fall 2017 üyesi
USFT-WALKUP-F17S5G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,560
