Ana içeriğe geç
Dell AC511 Front Panel Replacement
Neye ihtiyacın var
    1. Dell AC511 Front Panel Replacement, Front Panel: adım 1, 3 resimden 1. Dell AC511 Front Panel Replacement, Front Panel: adım 1, 3 resimden 2. Dell AC511 Front Panel Replacement, Front Panel: adım 1, 3 resimden 3.
      • Use a Jimmy to peel off the screen stuck to the front of the speaker.
      • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
      • Be careful to avoid damage to the rest of the speaker and especially to yourself.
      • Don't worry if it tears; use the Jimmy again to peel off the rest.
      FixBot'a Sor
      Yorum Ekle
    2. Dell AC511 Front Panel Replacement: adım 2, 2 resimden 1. Dell AC511 Front Panel Replacement: adım 2, 2 resimden 2.
      • Remove ten 6 mm screws using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Dell AC511 Front Panel Replacement: adım 3, 2 resimden 1. Dell AC511 Front Panel Replacement: adım 3, 2 resimden 2.
      • Lift the front panel off of the rest of the device.
      • The speakers will still be attached to the front panel. Being too rough could damage them.
      • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
      • Remove the front panel from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
William Cook
653 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G6
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 58
Her zaman: 1,448
