Ana içeriğe geç
Dell AC511 USB Cable Replacement
Neye ihtiyacın var
  1. Dell AC511 USB Cable Replacement, Front Panel: adım 1, 3 resimden 1. Dell AC511 USB Cable Replacement, Front Panel: adım 1, 3 resimden 2. Dell AC511 USB Cable Replacement, Front Panel: adım 1, 3 resimden 3.
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 USB Cable Replacement: adım 2, 2 resimden 1. Dell AC511 USB Cable Replacement: adım 2, 2 resimden 2.
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 USB Cable Replacement: adım 3, 2 resimden 1. Dell AC511 USB Cable Replacement: adım 3, 2 resimden 2.
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 USB Cable Replacement, Speaker: adım 4, 2 resimden 1. Dell AC511 USB Cable Replacement, Speaker: adım 4, 2 resimden 2.
    • Follow the three wires connected to the speaker to find where they connect to the circuit board.
    • Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
  5. Dell AC511 USB Cable Replacement, USB Cable: adım 5, 2 resimden 1. Dell AC511 USB Cable Replacement, USB Cable: adım 5, 2 resimden 2.
    • Depending on where the soundbar is damaged, there are two different ways to remove the USB cable. This guide will cover both scenarios.
    • Remove the 6 mm screws connecting the circuit board to the rear panel using a Phillips #1 screwdriver.
  6. Dell AC511 USB Cable Replacement: adım 6, 2 resimden 1. Dell AC511 USB Cable Replacement: adım 6, 2 resimden 2.
    • If the small wires coming from the USB cable are disconnected from the board, you'll have to solder them on. We recommend not letting that happen if you can help it.
    • The small wires may be glued to the circuit board. Pry off the glue with the Halberd Spudger.
  7. Dell AC511 USB Cable Replacement: adım 7, 1 resimden 1.
    • Follow this step if the wires are still connected. If they aren't, skip to the next step.
    • If the wiring to the circuit board seems fine, use a razor or wire strippers to clear the rubber insulation away from the USB.
    • Keep track of the colors! If you connect the wrong wires together, the speaker won't work, and you could ruin the board!
    • After removing the rubber insulation from the smaller wires, remove the access USB.
    • Splice in the new USB and wrap the connection with the colored wires in electrical tape.
    • If you end up with reduced sound quality, you may need to solder after all. Continue to the next step in that case.
  8. Dell AC511 USB Cable Replacement: adım 8, 1 resimden 1.
    • Follow this step if the wires are not connected.
    • Remove the old USB wiring as best as possible from the circuit board.
    • Try to not be too rough. If needed, use wire strippers to remove the wires.
    • Remember the locations of the color coded USB wires and solder each into their respective places.
    • Take your time. Do not add too much solder; you could potentially fry the board if you do.
Sonuç
William Cook
653 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G6
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 27
Her zaman: 432
