Ana içeriğe geç
Dell AC511 Volume Knob Replacement
Neye ihtiyacın var
  1. Dell AC511 Volume Knob Replacement, Front Panel: adım 1, 3 resimden 1. Dell AC511 Volume Knob Replacement, Front Panel: adım 1, 3 resimden 2. Dell AC511 Volume Knob Replacement, Front Panel: adım 1, 3 resimden 3.
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
    FixBot'a Sor
    Yorum Ekle
  2. Dell AC511 Volume Knob Replacement: adım 2, 2 resimden 1. Dell AC511 Volume Knob Replacement: adım 2, 2 resimden 2.
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Dell AC511 Volume Knob Replacement: adım 3, 2 resimden 1. Dell AC511 Volume Knob Replacement: adım 3, 2 resimden 2.
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Dell AC511 Volume Knob Replacement, Volume Knob: adım 4, 1 resimden 1.
    • Apply a light downward pressure on the circuit board next to the volume control.
    • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
    FixBot'a Sor
    Yorum Ekle
  5. Dell AC511 Volume Knob Replacement: adım 5, 1 resimden 1.
    • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
    • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
    FixBot'a Sor
    Yorum Ekle
Sonuç
William Cook
653 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G6
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 364
