Ana içeriğe geç
Dell AC511 Volume Knob Replacement
Neye ihtiyacın var
  1. Dell AC511 Volume Knob Replacement, Front Panel: adım 1, 3 resimden 1. Dell AC511 Volume Knob Replacement, Front Panel: adım 1, 3 resimden 2. Dell AC511 Volume Knob Replacement, Front Panel: adım 1, 3 resimden 3.
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Volume Knob Replacement: adım 2, 2 resimden 1. Dell AC511 Volume Knob Replacement: adım 2, 2 resimden 2.
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Volume Knob Replacement: adım 3, 2 resimden 1. Dell AC511 Volume Knob Replacement: adım 3, 2 resimden 2.
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Volume Knob Replacement, Volume Knob: adım 4, 1 resimden 1.
    • Apply a light downward pressure on the circuit board next to the volume control.
    • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
  5. Dell AC511 Volume Knob Replacement: adım 5, 1 resimden 1.
    • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
    • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
Sonuç
William Cook
617 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G6
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 75
