Ana içeriğe geç
Dell Adamo XPS Bridge Battery Replacement
Neye ihtiyacın var
    • Turn off the laptop before doing anything to the laptop.
    • Then turn the laptop around on its back.
    FixBot'a Sor
    Yorum Ekle
    • On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
    • Then you have to push the computer battery towards the computer and rotate upwards.
    • Finally lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
    • Turn the computer around and remove the eighteen screws on the base cover.
    • The screws that secure the base cover are of different sizes. Note the location and size of the screws as you remove them so that you can replace them correctly
    FixBot'a Sor
    Yorum Ekle
    • You aren't actually taking apart the display but only opening it up to gain access to the palm rest panel and keyboard.
    FixBot'a Sor
    Yorum Ekle
    • Use your fingers to ease the palm rest assembly from the computer.
    • Pull on the plastic tab on top of the cables to avoid damaging the connectors.
    • Exercise extreme care while lifting the palm rest assembly to avoid damaging the function key cable.
    FixBot'a Sor
    Yorum Ekle
    • Lift the palm rest assembly to access the function key cable.
    • To prevent damage to the function key cable, do not disconnect the function key cable from the palm rest.
    FixBot'a Sor
    Yorum Ekle
    • Disconnect the function key cable from the connector on the system board.
    FixBot'a Sor
    Yorum Ekle
    • Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
    • To prevent damage to the display hinges, ensure that you do not adjust the angle between the display and the computer base after removing the palm rest assembly.
    FixBot'a Sor
    Yorum Ekle
    • Lift the palm rest assembly off the computer base.
    FixBot'a Sor
    Yorum Ekle
    • After removing the laptop battery and the pal rest panel.
    • Disconnect the bridge battery cable from the connector on the left daughter board.
    • Be careful prying out the bridge battery.
    • The bridge battery is glued to the base cover. Use the spudger to pry the bridge battery out of the base cover.
    FixBot'a Sor
    Yorum Ekle
    • Use adhesive on the bridge battery to ahere it to the base cover.
    • Reconnect the bridge battery cable to the connector on the left daughter board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Christopher Melo-Pelaez
1.921 İtibar
9 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.002 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 41
Her zaman: 648
