Ana içeriğe geç
Dell Alienware 13 Camera Replacement
Neye ihtiyacın var
  1. Dell Alienware 13 Camera Replacement, Base Panel: adım 1, 1 resimden 1.
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Camera Replacement: adım 2, 1 resimden 1.
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Camera Replacement: adım 3, 3 resimden 1. Dell Alienware 13 Camera Replacement: adım 3, 3 resimden 2. Dell Alienware 13 Camera Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  4. Dell Alienware 13 Camera Replacement, Pull Tab: adım 5, 1 resimden 1.
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  5. Dell Alienware 13 Camera Replacement, Disconnecting the State Drive: adım 6, 1 resimden 1.
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  6. Dell Alienware 13 Camera Replacement, Remove Screws: adım 7, 1 resimden 1.
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  7. Dell Alienware 13 Camera Replacement, Solid-State Drive Assembly Lift: adım 8, 2 resimden 1. Dell Alienware 13 Camera Replacement, Solid-State Drive Assembly Lift: adım 8, 2 resimden 2.
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  8. Dell Alienware 13 Camera Replacement, Slide and Lift: adım 9, 1 resimden 1.
    • Slide and lift the solid-state drive off the solid-state assembly.
  9. Dell Alienware 13 Camera Replacement, Replacing the Solid-State Drive: adım 10, 1 resimden 1.
    • Slide the new solid-state drive into the solid-state drive assembly.
  10. Dell Alienware 13 Camera Replacement, Replace the Screw: adım 11, 1 resimden 1.
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  11. Dell Alienware 13 Camera Replacement, Screw Align: adım 12, 1 resimden 1.
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  12. Dell Alienware 13 Camera Replacement, Screw Replacement: adım 13, 1 resimden 1.
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  13. Dell Alienware 13 Camera Replacement, Connecting the Drive: adım 14, 1 resimden 1.
    • Connect the solid-state drive cable to the system board.
  14. Dell Alienware 13 Camera Replacement, Aligning Screws: adım 15, 1 resimden 1.
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  15. Dell Alienware 13 Camera Replacement, Replacing Screws: adım 16, 1 resimden 1.
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  16. Dell Alienware 13 Camera Replacement, Disconnecting the Keyboard: adım 17, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
  17. Dell Alienware 13 Camera Replacement, Removing the Screws: adım 18, 2 resimden 1. Dell Alienware 13 Camera Replacement, Removing the Screws: adım 18, 2 resimden 2.
    • Remove the screws that secure the palm-rest assembly to the computer base.
  18. Dell Alienware 13 Camera Replacement, Popping out the Palm-Rest Assembly: adım 19, 1 resimden 1.
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
  19. Dell Alienware 13 Camera Replacement, Turn the Computer Over: adım 20, 1 resimden 1.
    • Turn the computer over and open the display as far as possible.
  20. Dell Alienware 13 Camera Replacement, Prying the Edges: adım 21, 1 resimden 1.
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  21. Dell Alienware 13 Camera Replacement, Lifting the Palm-Rest Assembly: adım 22, 1 resimden 1.
    • Gently lift the palm-rest assembly and turn it over.
  22. Dell Alienware 13 Camera Replacement, Disconnecting the Power-Board Cable: adım 23, 2 resimden 1. Dell Alienware 13 Camera Replacement, Disconnecting the Power-Board Cable: adım 23, 2 resimden 2.
    • Lift the connector latch and disconnect the power-button board cable from the system board.
    • Remove the Keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
  23. Dell Alienware 13 Camera Replacement, Connecting the Power-Button Board Cable: adım 26, 1 resimden 1.
    • Connect the power-button board cable to the system board.
  24. Dell Alienware 13 Camera Replacement, Aligning the Palm-Rest Assembly.: adım 27, 1 resimden 1.
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Close the display and turn the computer over.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  25. Dell Alienware 13 Camera Replacement, Open the Display: adım 31, 1 resimden 1.
  26. Dell Alienware 13 Camera Replacement, Removing the Screws: adım 32, 2 resimden 1. Dell Alienware 13 Camera Replacement, Removing the Screws: adım 32, 2 resimden 2.
    • Remove the screws that secure the hinge caps to the display hinges.
  27. Dell Alienware 13 Camera Replacement, Lift the Hinge Caps: adım 33, 1 resimden 1.
    • Slide and lift the hinge caps off the display hinges.
  28. Dell Alienware 13 Camera Replacement, Close the Display: adım 34, 1 resimden 1.
  29. Dell Alienware 13 Camera Replacement, Peeling the Adhesive Tape: adım 35, 1 resimden 1.
    • Peel off the adhesive tape from the wireless card.
  30. Dell Alienware 13 Camera Replacement, Remove the Screw: adım 36, 1 resimden 1.
    • Remove the screw that secures the wireless-card bracket to the wireless card.
  31. Dell Alienware 13 Camera Replacement, Disconnecting the Antenna Cables: adım 37, 1 resimden 1.
    • Disconnect the antenna cables from the wireless card.
    • Turn the computer over and open the display.
  32. Dell Alienware 13 Camera Replacement, Peeling the Adhesive Tapes: adım 39, 1 resimden 1.
    • Peel off the adhesive tapes that secure the antenna cables to the system board.
    • Make note of the cable routing before removing any cable from its routing guide.
  33. Dell Alienware 13 Camera Replacement, Removing the Antenna Cables: adım 40, 1 resimden 1.
    • Remove the antenna cables from the routing guides on the display hinges.
  34. Dell Alienware 13 Camera Replacement, Disconnecting the Display Cable: adım 41, 2 resimden 1. Dell Alienware 13 Camera Replacement, Disconnecting the Display Cable: adım 41, 2 resimden 2.
    • Lift the connector latch and disconnect the display cable from the system board.
  35. Dell Alienware 13 Camera Replacement, Removing the Display Cable: adım 42, 1 resimden 1.
    • Remove the display cable from the routing guides on the display hinges.
  36. Dell Alienware 13 Camera Replacement, Disconnecting the Logo-Board Cable: adım 43, 1 resimden 1.
    • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
  37. Dell Alienware 13 Camera Replacement, Removing the Screws: adım 44, 1 resimden 1.
    • Remove the screws that secure the display assembly to the computer base.
  38. Dell Alienware 13 Camera Replacement, Lifting the Display Assembly: adım 45, 1 resimden 1.
    • Lift the display assembly off the computer base.
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  39. Dell Alienware 13 Camera Replacement, Replacing the Screws: adım 47, 1 resimden 1.
    • Replace the screws that secure the display hinges to the computer base.
  40. Dell Alienware 13 Camera Replacement, Connecting the Logo-Board Cable: adım 48, 1 resimden 1.
    • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
  41. Dell Alienware 13 Camera Replacement, Routing the Display Cable: adım 49, 1 resimden 1.
    • Route the display cable through the routing guides on the display hinge.
  42. Dell Alienware 13 Camera Replacement, Sliding the Display Cable: adım 50, 1 resimden 1.
    • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
  43. Dell Alienware 13 Camera Replacement, Route the Antenna Cables: adım 51, 1 resimden 1.
    • Route the antenna cables through the routing guides on the display hinges.
  44. Dell Alienware 13 Camera Replacement, Adhering the Tapes: adım 52, 1 resimden 1.
    • Adhere the adhesive tapes that secure the antenna cables to the system board.
  45. Dell Alienware 13 Camera Replacement, Connecting the Antenna Cables: adım 54, 1 resimden 1.
    • Connect the antenna cables to the wireless card.
  46. Dell Alienware 13 Camera Replacement, Replace the Screw: adım 55, 2 resimden 1. Dell Alienware 13 Camera Replacement, Replace the Screw: adım 55, 2 resimden 2.
    • Replace the screw that secures the wireless-card bracket to the wireless card.
  47. Dell Alienware 13 Camera Replacement, Adhering the Adhesive Tape: adım 56, 1 resimden 1.
    • Adhere the adhesive tape to the wireless card.
  48. Dell Alienware 13 Camera Replacement, Align the Screw Holes: adım 58, 1 resimden 1.
    • Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Replace the screws that secure the hinge caps to the display hinges.
  49. Dell Alienware 13 Camera Replacement, Disconnecting the Touchpad Cable: adım 60, 3 resimden 1. Dell Alienware 13 Camera Replacement, Disconnecting the Touchpad Cable: adım 60, 3 resimden 2. Dell Alienware 13 Camera Replacement, Disconnecting the Touchpad Cable: adım 60, 3 resimden 3.
    • Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
  50. Dell Alienware 13 Camera Replacement, Peeling the Cables: adım 61, 1 resimden 1.
    • Peel the touchpad cable and status-light cable off the keyboard bracket.
  51. Dell Alienware 13 Camera Replacement, Removing the Keyboard Bracket: adım 62, 1 resimden 1.
    • Lift the keyboard bracket off the palm-rest assembly.
  52. Dell Alienware 13 Camera Replacement, Remove the Screws: adım 63, 1 resimden 1.
    • Remove the screws that secure the keyboard to the palm-rest assembly.
  53. Dell Alienware 13 Camera Replacement, Lifting the Keyboard: adım 64, 1 resimden 1.
    • Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
  54. Dell Alienware 13 Camera Replacement, Aligning the Screw Holes: adım 65, 1 resimden 1.
    • Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
  55. Dell Alienware 13 Camera Replacement, Replacing Screws: adım 66, 1 resimden 1.
    • Replace the screws that secure the keyboard to the palm-rest assembly.
    • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
  56. Dell Alienware 13 Camera Replacement, Replace the Screws: adım 68, 1 resimden 1.
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
  57. Dell Alienware 13 Camera Replacement, Adhering the Cables: adım 69, 2 resimden 1. Dell Alienware 13 Camera Replacement, Adhering the Cables: adım 69, 2 resimden 2.
    • Adhere the touchpad cable and status-light cable to the keyboard bracket.
  58. Dell Alienware 13 Camera Replacement, Sliding the Cables: adım 70, 1 resimden 1.
    • Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
  59. Dell Alienware 13 Camera Replacement, Prying the Edges: adım 71, 1 resimden 1.
    • Using your fingertips, carefully pry up the inside edges of the display bezel.
  60. Dell Alienware 13 Camera Replacement, Lift the Display Bezel: adım 72, 1 resimden 1.
    • Carefully lift the display bezel and turn it over.
    • Lift the connector latches and disconnect the display-board cables from the logo board.
  61. Dell Alienware 13 Camera Replacement, Disconnect the Logo-Board Cable: adım 74, 2 resimden 1. Dell Alienware 13 Camera Replacement, Disconnect the Logo-Board Cable: adım 74, 2 resimden 2.
    • Disconnect the logo-board cable from the logo board.
    • Connect the logo-board cable to the logo board.
    • Slide the display-board cables to their respective connectors on the logo board and press down the latches to secure the cables.
    • Turn the NEW display bezel over.
  62. Dell Alienware 13 Camera Replacement, Align the Display Bezel: adım 78, 1 resimden 1.
    • Align the display bezel with the display back-cover and gently snap the display bezel into place.
  63. Dell Alienware 13 Camera Replacement, Remove the Screws: adım 79, 3 resimden 1. Dell Alienware 13 Camera Replacement, Remove the Screws: adım 79, 3 resimden 2. Dell Alienware 13 Camera Replacement, Remove the Screws: adım 79, 3 resimden 3.
    • Remove the screws that secure the display panel to the display back-cover.
  64. Dell Alienware 13 Camera Replacement, Lift the Display Panel: adım 80, 1 resimden 1.
    • Gently lift the display panel and turn it over.
  65. Dell Alienware 13 Camera Replacement, Lift the Connector Latch: adım 81, 3 resimden 1. Dell Alienware 13 Camera Replacement, Lift the Connector Latch: adım 81, 3 resimden 2. Dell Alienware 13 Camera Replacement, Lift the Connector Latch: adım 81, 3 resimden 3.
    • Lift the connector latch and disconnect the display cable from the display panel.
  66. Dell Alienware 13 Camera Replacement, Securing the Cable: adım 82, 3 resimden 1. Dell Alienware 13 Camera Replacement, Securing the Cable: adım 82, 3 resimden 2. Dell Alienware 13 Camera Replacement, Securing the Cable: adım 82, 3 resimden 3.
    • Connect the display cable to the NEW display panel and press down on the connector latch to secure the cable.
    • Turn the display panel over.
  67. Dell Alienware 13 Camera Replacement, Align the Screw Holes: adım 84, 1 resimden 1.
    • Align the screw holes on the display panel with the screw holes on the display back-cover.
  68. Dell Alienware 13 Camera Replacement, Replace the Screws: adım 85, 1 resimden 1.
    • Replace the screws that secure the display panel to the display back-cover.
  69. Dell Alienware 13 Camera Replacement, Place the Display: adım 86, 1 resimden 1.
  70. Dell Alienware 13 Camera Replacement, Disconnecting the Camera Cable: adım 87, 2 resimden 1. Dell Alienware 13 Camera Replacement, Disconnecting the Camera Cable: adım 87, 2 resimden 2.
    • Disconnect the camera cable from the camera module.
  71. Dell Alienware 13 Camera Replacement, Pry the Camera Module: adım 88, 2 resimden 1. Dell Alienware 13 Camera Replacement, Pry the Camera Module: adım 88, 2 resimden 2.
    • Using a plastic scribe, pry the camera module off the display back-cover.
  72. Dell Alienware 13 Camera Replacement, Snapping the Module in Place: adım 89, 1 resimden 1.
    • Using the alignment posts place the NEW camera module on the display back-cover and snap it into place.
  73. Dell Alienware 13 Camera Replacement, Connect the Camera Cable: adım 90, 2 resimden 1. Dell Alienware 13 Camera Replacement, Connect the Camera Cable: adım 90, 2 resimden 2.
    • Connect the camera cable to the camera module.
Sonuç
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 153
