Giriş
In this guide, we will be removing and replacing the memory module on the Dell Alienware 13 R2.
Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Slide and remove the memory module from the memory-module slot.
Using the new memory module, align the notch on the memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
