Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
In this guide, we will show you how to remove and replace the coin-cell battery.
Neye ihtiyacın var
Loosen the five captive screws that secure the base cover to the computer base.
Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
Using a plastic scribe, disconnect the battery cable from the system board.
Press and hold the power button for five seconds to ground the system board.
Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
Tighten the five captive screws that secure the base cover to the computer base.
Remove the screw (M2x3) that secures the solid-state drive to the computer base.
Lift and slide the solid-state drive from the solid-state drive slot.
Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Disconnect the coin-cell battery cable from the system board.
Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
Adhere the NEW coin-cell battery to the palm-rest assembly.
Connect the coin-cell battery cable to the system board.
