Giriş
In this guide, we will be showing you how to remove and replace the Solid-State Drive.
Parçalar
Hiçbir parça belirtilmedi.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  1. Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  2. Using the pull tab, disconnect the solid-state drive cable from the system board.
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  3. Remove the screws that secure the solid-state drive assembly to the computer base.
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  4. Lift the solid-state drive assembly off the computer base. Make sure the screws are off the solid-state assembly.
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  5. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  6. Slide and lift the solid-state drive off the solid-state assembly.
    • Slide and lift the solid-state drive off the solid-state assembly.
  7. CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • Slide the new solid-state drive into the solid-state drive assembly.
  8. Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  9. Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  10. Replace the screws that secure the solid-state drive assembly to the computer base.
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  11. Connect the solid-state drive cable to the system board.
    • Connect the solid-state drive cable to the system board.
  12. Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  13. Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Bitiş Çizgisi
Terrence15
71.512 Reputation
442 adet Kılavuz yazıldı
Informative Technologies Inc. Informative Technologies Inc. üyesi
Community
18 Üyeler
1.540 adet Kılavuz yazıldı
One Comment
Hi there. Could I have a link to the full service manual you got this from? Thanks.
Aiden Baker - Yanıt
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 7
All Time: 102
