Ana içeriğe geç
Dell Alienware 13 Solid-State Drive (SSD) Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  1. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Pull Tab: adım 2, 1 resimden 1.
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  2. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Disconnecting the State Drive: adım 3, 1 resimden 1.
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  3. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Remove Screws: adım 4, 1 resimden 1.
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  4. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Solid-State Drive Assembly Lift: adım 5, 2 resimden 1. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Solid-State Drive Assembly Lift: adım 5, 2 resimden 2.
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  5. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Slide and Lift: adım 6, 1 resimden 1.
    • Slide and lift the solid-state drive off the solid-state assembly.
  6. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replacing the Solid-State Drive: adım 7, 1 resimden 1.
    • Slide the new solid-state drive into the solid-state drive assembly.
  7. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replace the Screw: adım 8, 1 resimden 1.
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  8. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Screw Align: adım 9, 1 resimden 1.
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  9. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Screw Replacement: adım 10, 1 resimden 1.
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  10. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Connecting the Drive: adım 11, 1 resimden 1.
    • Connect the solid-state drive cable to the system board.
  11. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Aligning Screws: adım 12, 1 resimden 1.
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  12. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replacing Screws: adım 13, 1 resimden 1.
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Bitiş Çizgisi
Terrence15
79.121 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
Bir Yorum
Hi there. Could I have a link to the full service manual you got this from? Thanks.
Aiden - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 189
