Ana içeriğe geç
Dell Alienware 13 Touch pad Replacement
Neye ihtiyacın var
  1. Dell Alienware 13 Touch pad Replacement, Base Panel: adım 1, 1 resimden 1.
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Alienware 13 Touch pad Replacement: adım 2, 1 resimden 1.
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Alienware 13 Touch pad Replacement: adım 3, 3 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 3, 3 resimden 2. Dell Alienware 13 Touch pad Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    FixBot'a Sor
    Yorum Ekle
  4. Dell Alienware 13 Touch pad Replacement, Touch pad: adım 4, 2 resimden 1. Dell Alienware 13 Touch pad Replacement, Touch pad: adım 4, 2 resimden 2.
    • Disconnect the battery cable from the battery cable terminal.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Alienware 13 Touch pad Replacement: adım 5, 1 resimden 1.
    • Remove (4) 6 mm Phillips head screws from the solid-state metal drive bracket, using a Phillips # 1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Alienware 13 Touch pad Replacement: adım 6, 2 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 6, 2 resimden 2.
    • Grab the pull tab to pivot the solid-state drive bracket upwards. Remove the bracket from the computer base.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Alienware 13 Touch pad Replacement: adım 7, 2 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 7, 2 resimden 2.
    • Using the pull tab, disconnect the black solid-state drive cable from the system board.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Alienware 13 Touch pad Replacement: adım 8, 1 resimden 1.
    • Remove (2) 3 mm Phillips head screws, using a Phillips # 0 screwdriver, that connect the solid-state drive assembly to the computer base.
    FixBot'a Sor
    Yorum Ekle
  9. Dell Alienware 13 Touch pad Replacement: adım 9, 2 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 9, 2 resimden 2.
    • Lift up on the solid-state drive assembly to remove it from the computer base.
    FixBot'a Sor
    Yorum Ekle
  10. Dell Alienware 13 Touch pad Replacement: adım 10, 2 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 10, 2 resimden 2.
    • Locate two cables labeled, "KB Backlight" (orange) and "KB Membrane" (black). Lift up on the latches to disconnect the cables from the system board.
    FixBot'a Sor
    Yorum Ekle
  11. Dell Alienware 13 Touch pad Replacement: adım 11, 3 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 11, 3 resimden 2. Dell Alienware 13 Touch pad Replacement: adım 11, 3 resimden 3.
    • Remove (8) 9 mm Phillips head screws using a Phillips # 1 screwdriver, that secures the palm-rest assembly to the computer base.
    • Remove (4) 8 mm Phillips head screws using a Phillips # 1 screwdriver.
    • Remove (2) 7 mm Phillips head screws using a Phillips # 1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  12. Dell Alienware 13 Touch pad Replacement: adım 12, 2 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 12, 2 resimden 2.
    • Lift the computer base slightly towards you and push the release tabs on the palm-rest assembly until it pops out using a spudger.
    FixBot'a Sor
    Yorum Ekle
  13. Dell Alienware 13 Touch pad Replacement: adım 13, 3 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 13, 3 resimden 2. Dell Alienware 13 Touch pad Replacement: adım 13, 3 resimden 3.
    • Turn the computer over and open the display as far as possible.
    • Using a plastic spudger, pry up along the edges of the palm-rest assembly.
    • Gently lift the palm-rest assembly.
    FixBot'a Sor
    Yorum Ekle
  14. Dell Alienware 13 Touch pad Replacement: adım 14, 3 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 14, 3 resimden 2. Dell Alienware 13 Touch pad Replacement: adım 14, 3 resimden 3.
    • Lift the connector latch and disconnect the power-button board cable from the system board. Identified as a cable with a blue tab.
    • Lift the palm-rest assembly off the computer base.
    FixBot'a Sor
    Yorum Ekle
  15. Dell Alienware 13 Touch pad Replacement: adım 15, 2 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 15, 2 resimden 2.
    • Disconnect the touch pad cable from the touch pad.
    FixBot'a Sor
    Yorum Ekle
  16. Dell Alienware 13 Touch pad Replacement: adım 16, 3 resimden 1. Dell Alienware 13 Touch pad Replacement: adım 16, 3 resimden 2. Dell Alienware 13 Touch pad Replacement: adım 16, 3 resimden 3.
    • Remove (4) 3 mm Phillips head screws securing the touch pad to the palm rest assembly using a Phillips # 0 screwdriver.
    • Lift up and remove the touch pad from the palm rest assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Adam Russell
898 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-2, Eyestone Fall 2016 USF Tampa, Team 14-2, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S14G2
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 32
Her zaman: 611
