Ana içeriğe geç
Dell Alienware 14 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Alienware 14 Memory Module Replacement, Close the Display: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Alienware 14 Memory Module Replacement, Remove the Screws: adım 2, 2 resimden 1. Dell Alienware 14 Memory Module Replacement, Remove the Screws: adım 2, 2 resimden 2.
    • Remove the screws that secure the base cover to the computer base.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Alienware 14 Memory Module Replacement, Slide and Lift the Base Cover: adım 3, 1 resimden 1.
    • Slide and lift the base cover off the computer base.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Alienware 14 Memory Module Replacement, Align the Tabs: adım 4, 1 resimden 1.
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Alienware 14 Memory Module Replacement, Replace the Screws: adım 5, 1 resimden 1.
    • Replace the screws that secure the base cover to the computer base.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: adım 6, 1 resimden 1.
    • Turn the computer over and open the display.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Alienware 14 Memory Module Replacement, Disconnecting the Battery Cable: adım 7, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Alienware 14 Memory Module Replacement, Remove the Screws: adım 8, 1 resimden 1.
    • Remove the screws that secure the battery to the computer base.
    FixBot'a Sor
    Yorum Ekle
  9. Dell Alienware 14 Memory Module Replacement, Using the Battery Cable: adım 9, 1 resimden 1.
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
    FixBot'a Sor
    Yorum Ekle
  10. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: adım 10, 1 resimden 1.
    • Turn the computer over and open the display as far as possible.
    FixBot'a Sor
    Yorum Ekle
  11. Dell Alienware 14 Memory Module Replacement, The Power Button: adım 11, 1 resimden 1.
    • Press and hold the power button for five seconds to ground the system board.
    FixBot'a Sor
    Yorum Ekle
    • Close the display and turn the computer over.
    FixBot'a Sor
    Yorum Ekle
  12. Dell Alienware 14 Memory Module Replacement, Align the Tabs: adım 13, 1 resimden 1.
    • Align the tabs on the NEW battery with the slots on the computer base.
    FixBot'a Sor
    Yorum Ekle
  13. Dell Alienware 14 Memory Module Replacement, Align the Screw Holes: adım 14, 1 resimden 1.
    • Align the screw holes on the battery with the screw holes on the computer base.
    FixBot'a Sor
    Yorum Ekle
  14. Dell Alienware 14 Memory Module Replacement, Replace the Screws: adım 15, 1 resimden 1.
    • Replace the screws that secure the battery to the computer base.
    FixBot'a Sor
    Yorum Ekle
  15. Dell Alienware 14 Memory Module Replacement, Connect the Battery Cable: adım 16, 1 resimden 1.
    • Connect the battery cable to the system-board connector.
    FixBot'a Sor
    Yorum Ekle
  16. Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: adım 17, 3 resimden 1. Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: adım 17, 3 resimden 2. Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: adım 17, 3 resimden 3.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    FixBot'a Sor
    Yorum Ekle
  17. Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: adım 18, 2 resimden 1. Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: adım 18, 2 resimden 2.
    • Remove the memory module from the memory-module connector.
    FixBot'a Sor
    Yorum Ekle
  18. Dell Alienware 14 Memory Module Replacement, Align the Notch: adım 19, 2 resimden 1. Dell Alienware 14 Memory Module Replacement, Align the Notch: adım 19, 2 resimden 2.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
    FixBot'a Sor
    Yorum Ekle
  19. Dell Alienware 14 Memory Module Replacement, Slide the Memory Module: adım 20, 1 resimden 1.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Terrence15
80.125 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 539
