Ana içeriğe geç
Dell Alienware 14 Power-Button Board Replacement
Neye ihtiyacın var
  1. Dell Alienware 14 Power-Button Board Replacement, Close the Display: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: adım 2, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: adım 2, 2 resimden 2.
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Power-Button Board Replacement, Slide and Lift the Base Cover: adım 3, 1 resimden 1.
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Power-Button Board Replacement, Align the Tabs: adım 4, 1 resimden 1.
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: adım 5, 1 resimden 1.
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Power-Button Board Replacement, Turn the Computer Over: adım 6, 1 resimden 1.
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Battery Cable: adım 7, 1 resimden 1.
  8. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: adım 8, 1 resimden 1.
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Power-Button Board Replacement, Using the Battery Cable: adım 9, 1 resimden 1.
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Power-Button Board Replacement, Turn the Computer Over: adım 10, 1 resimden 1.
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Power-Button Board Replacement, The Power Button: adım 11, 1 resimden 1.
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Power-Button Board Replacement, Align the Tabs: adım 13, 1 resimden 1.
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Holes: adım 14, 1 resimden 1.
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: adım 15, 1 resimden 1.
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Power-Button Board Replacement, Connect the Battery Cable: adım 16, 1 resimden 1.
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: adım 17, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: adım 17, 2 resimden 2.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
    • Remove the screws that secure the secondary hard-drive assembly to the computer base.
  17. Dell Alienware 14 Power-Button Board Replacement, Lifting the Secondary Hard-Drive: adım 18, 3 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Lifting the Secondary Hard-Drive: adım 18, 3 resimden 2. Dell Alienware 14 Power-Button Board Replacement, Lifting the Secondary Hard-Drive: adım 18, 3 resimden 3.
    • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
  18. Dell Alienware 14 Power-Button Board Replacement, Lifting the Hard Drive: adım 19, 1 resimden 1.
    • Lift the secondary hard-drive assembly off the computer base.
  19. Dell Alienware 14 Power-Button Board Replacement, Turn the Assembly Over: adım 20, 1 resimden 1.
    • Turn the secondary hard-drive assembly over.
  20. Dell Alienware 14 Power-Button Board Replacement, Remove the Screw: adım 21, 1 resimden 1.
    • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
  21. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: adım 22, 1 resimden 1.
    • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  22. Dell Alienware 14 Power-Button Board Replacement, Slide and Lift the Hard-Drive: adım 23, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Slide and Lift the Hard-Drive: adım 23, 2 resimden 2.
    • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
  23. Dell Alienware 14 Power-Button Board Replacement, Disconnect the Interposer: adım 24, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Disconnect the Interposer: adım 24, 2 resimden 2.
    • Disconnect the interposer from the secondary hard-drive connector.
  24. Dell Alienware 14 Power-Button Board Replacement, Connect the Interposer: adım 25, 1 resimden 1.
    • Connect the interposer to the secondary hard-drive connector.
  25. Dell Alienware 14 Power-Button Board Replacement, Placing the Secondary Hard-Drive: adım 26, 1 resimden 1.
    • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
  26. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Holes: adım 27, 1 resimden 1.
    • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
  27. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: adım 28, 1 resimden 1.
    • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  28. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Hole: adım 29, 1 resimden 1.
    • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
  29. Dell Alienware 14 Power-Button Board Replacement, Replace the Screw: adım 30, 1 resimden 1.
    • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
  30. Dell Alienware 14 Power-Button Board Replacement, Turn the Hard-Drive Assembly Over: adım 31, 1 resimden 1.
  31. Dell Alienware 14 Power-Button Board Replacement, Slide the Hard-Drive Cable: adım 32, 1 resimden 1.
    • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
  32. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Holes: adım 33, 1 resimden 1.
    • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
    • Replace the screws that secure the secondary hard-drive assembly to the computer base.
  33. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Status-Light Board Cable: adım 35, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Status-Light Board Cable: adım 35, 2 resimden 2.
    • Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
  34. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: adım 36, 1 resimden 1.
    • Remove the screws that secure the palm -rest assembly to the computer base.
  35. Dell Alienware 14 Power-Button Board Replacement, Turn the Computer Over: adım 37, 1 resimden 1.
  36. Dell Alienware 14 Power-Button Board Replacement, Pry the Palm-Rest Assembly: adım 38, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Pry the Palm-Rest Assembly: adım 38, 2 resimden 2.
    • Using a plastic scribe, pry the palm-rest assembly from the computer base.
  37. Dell Alienware 14 Power-Button Board Replacement, Lift the Palm-Rest Assembly: adım 39, 1 resimden 1.
    • Carefully lift the palm-rest assembly and turn it over.
  38. Dell Alienware 14 Power-Button Board Replacement, Release the Connector Latches: adım 40, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Release the Connector Latches: adım 40, 2 resimden 2.
    • Release the connector latches to disconnect the flexi-cable from the system board.
    • Connect the flexi-cable to the connector on the system board.
  39. Dell Alienware 14 Power-Button Board Replacement, Turn the Palm-Rest Assembly: adım 44, 1 resimden 1.
    • Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
    • Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
  40. Dell Alienware 14 Power-Button Board Replacement, Close the Display: adım 46, 1 resimden 1.
  41. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: adım 47, 1 resimden 1.
    • Replace the screws that secure the palm-rest assembly to the computer base.
  42. Dell Alienware 14 Power-Button Board Replacement, Slide the Status-Light Board Cable: adım 48, 1 resimden 1.
    • Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
  43. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Power-Button Board Cable: adım 49, 3 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Power-Button Board Cable: adım 49, 3 resimden 2. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Power-Button Board Cable: adım 49, 3 resimden 3.
    • Lift the connector latch and disconnect the power-button board cable from the connector on the status-light board.
  44. Dell Alienware 14 Power-Button Board Replacement, Peeling the Power-Button Board Cable: adım 50, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Peeling the Power-Button Board Cable: adım 50, 2 resimden 2.
    • Make a note of the power-button board cable routing and peel off the power-button board cable from the keyboard bracket.
  45. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: adım 51, 1 resimden 1.
    • Remove the screws that secure the power-button board to the palm-rest assembly.
  46. Dell Alienware 14 Power-Button Board Replacement, Lifting the Power-Button Board: adım 52, 1 resimden 1.
    • Lift the power-button board along with its cable off the palm-rest assembly.
  47. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Holes: adım 53, 1 resimden 1.
    • Align the screw holes on the NEW power-button board with the screw holes on the palm-rest assembly.
  48. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: adım 54, 1 resimden 1.
    • Replace the screws that secure the power-button board to the palm-rest assembly.
  49. Dell Alienware 14 Power-Button Board Replacement, Route the Power-Button Board: adım 55, 1 resimden 1.
    • Route the power-button board cable on the keyboard bracket and adhere the cable to the keyboard bracket.
  50. Dell Alienware 14 Power-Button Board Replacement, Slide the Power-Button Board Cable: adım 56, 2 resimden 1. Dell Alienware 14 Power-Button Board Replacement, Slide the Power-Button Board Cable: adım 56, 2 resimden 2.
    • Slide the power-button board cable into the status-light board connector and press down on the connector latch to secure the cable.
Sonuç
Terrence15
79.549 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 459
