Ana içeriğe geç
Dell Alienware 15 Base Panel Replacement
Neye ihtiyacın var
    • After turning the computer off, close the display and turn the computer over.
  1. Dell Alienware 15 Base Panel Replacement, Remove the Back Panel Screws and Lift: adım 2, 1 resimden 1.
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
  2. Dell Alienware 15 Base Panel Replacement, Optional: Disconnect the Battery: adım 3, 1 resimden 1.
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
Sonuç
To reassemble the computer, follow these instructions in reverse order and screw on the replacement panel instead of the original panel if a new one is to be used.
Bir başkası bu kılavuzu tamamladı.
William Daniels
824 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 556
