Ana içeriğe geç
Dell Alienware 15 R3 Battery Replacement
Neye ihtiyacın var
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: adım 1, 3 resimden 1. Dell Alienware 15 R3 Battery Replacement, Back Case: adım 1, 3 resimden 2. Dell Alienware 15 R3 Battery Replacement, Back Case: adım 1, 3 resimden 3.
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Alienware 15 R3 Battery Replacement: adım 2, 1 resimden 1.
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Alienware 15 R3 Battery Replacement: adım 4, 2 resimden 1. Dell Alienware 15 R3 Battery Replacement: adım 4, 2 resimden 2.
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Alienware 15 R3 Battery Replacement: adım 5, 3 resimden 1. Dell Alienware 15 R3 Battery Replacement: adım 5, 3 resimden 2. Dell Alienware 15 R3 Battery Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Alienware 15 R3 Battery Replacement, Battery: adım 6, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Alienware 15 R3 Battery Replacement: adım 7, 3 resimden 1. Dell Alienware 15 R3 Battery Replacement: adım 7, 3 resimden 2. Dell Alienware 15 R3 Battery Replacement: adım 7, 3 resimden 3.
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jake Nelson
642 İtibar
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
does not seem to be for my alienware r3 15 inch
Craig Anderson - Yanıt Paylaş
step 5 - you need to unscrew 10 screws, not 9. You missed the one in the center.
Mike Kravchenko - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 36
Son 30 gün: 181
Her zaman: 10,378
