Giriş
If you are trying to replace the motherboard for the Dell Alienware 15 R3 this is a step by step guide to help you.
Before you begin the repair, power off your laptop and unplug the power adapter. When you get to Step 6, it's important to disconnect the battery cable from the motherboard and remove the battery.
Neye ihtiyacın var
Flip the laptop over so that the backside is facing up.
Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
The Wlan cable holds the base to the computer along with a little wire in the back left corner.
Mine has 12 screws not 9. one card also to remove, (held by screw), and 2 sets of connectors
Plus you need to put the splonger in the edge below the usb connections, not on the area highlighted in the picture above. Yeah there are way more screws than 9. You also need to remove the screws out of any m.2 ssd drives, msata drives, and wlan card. You also need to unplug each ribbon cable, and unplug and unwire the tronlights on both sides of the laptop.
This youtube video is really helpful for this part: https://youtu.be/QxJznOkvyic?si=eDLzrheu...
jason -
Before you begin, disconnect the battery cable from the motherboard. Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the battery cable out.
Use a Phillips #00 screwdriver to remove the eleven screws connecting the fan to the motherboard.
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
This guide completely skips disengaging the battery, which should be done before any components, and it should be plugged back in last.
Well, anyone in their right mind, would know that is the 1st thing to do. Give him credit for a great picturess of disassembling... :-)
Actually "Step 6" tells you to do just that !!!
