Ana içeriğe geç
Dell Alienware 15 R3 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: adım 1, 3 resimden 1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: adım 1, 3 resimden 2. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: adım 1, 3 resimden 3.
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Wi-Fi Card Replacement, Cover Assembly: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Dell Alienware 15 R3 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Wi-Fi Card Replacement: adım 5, 3 resimden 1. Dell Alienware 15 R3 Wi-Fi Card Replacement: adım 5, 3 resimden 2. Dell Alienware 15 R3 Wi-Fi Card Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: adım 6, 3 resimden 1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: adım 6, 3 resimden 2. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: adım 6, 3 resimden 3.
    • Open the flap to reveal the Wi-Fi card.
    • Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
    • Use a spudger to detach the coaxial cables from the Wi-Fi card.
    • Be careful when detaching these cable connectors from the Wi-Fi card. The base of the connectors are prone to break off.
Sonuç
Jake Nelson
623 İtibar
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 519
