Ana içeriğe geç
Dell Alienware 17 Memory Modules 1 & 2 Replacement
Neye ihtiyacın var
  1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, turning the computer over: adım 1, 1 resimden 1.
  2. Dell Alienware 17 Memory Modules 1 & 2 Replacement, removing screws: adım 2, 1 resimden 1.
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 17 Memory Modules 1 & 2 Replacement, slide base cover: adım 3, 1 resimden 1.
    • Slide the base cover toward the front of the computer.
  4. Dell Alienware 17 Memory Modules 1 & 2 Replacement, remove the base cover: adım 4, 1 resimden 1.
    • Lift the base cover off.
  5. Dell Alienware 17 Memory Modules 1 & 2 Replacement, replacing base cover: adım 5, 1 resimden 1.
    • Align the tabs on the new base cover with the slots on the computer base
  6. Dell Alienware 17 Memory Modules 1 & 2 Replacement, placing screw: adım 6, 1 resimden 1.
    • Slide the base cover toward the back of the computer and align the screws holes on the base cover with the screw holes on the computer base.
  7. Dell Alienware 17 Memory Modules 1 & 2 Replacement, secure base cover: adım 7, 1 resimden 1.
    • Replace the screws that secure the base cover to the computer base.
  8. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Disconnecting the Battery Cable: adım 8, 1 resimden 1.
  9. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: adım 9, 1 resimden 1.
    • Remove the screws that secure the battery to the computer base.
  10. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Releasing the Battery: adım 10, 2 resimden 1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Releasing the Battery: adım 10, 2 resimden 2.
    • Using the battery cable, lift and release the battery from the tabs on the computer base.
  11. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Opening the Display: adım 11, 1 resimden 1.
    • Turn the computer over and open the display.
  12. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Grounding the System Board: adım 12, 1 resimden 1.
    • Press and hold the power button for five seconds to ground the system board.
  13. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Slide the New Battery: adım 13, 1 resimden 1.
    • Slide the NEW battery under the tabs on the computer base.
  14. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Aligning the Screw Holes: adım 14, 1 resimden 1.
    • Align the screw holes on the battery with the screw holes on the computer base.
  15. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: adım 15, 1 resimden 1.
    • Replace the screws that secure the battery to the computer base.
  16. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Connect the Battery Cable: adım 16, 1 resimden 1.
    • Connect the battery cable to the system board.
  17. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: adım 17, 2 resimden 1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: adım 17, 2 resimden 2.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. . After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extr emely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  18. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Assembly: adım 18, 1 resimden 1.
    • Using the pull-tab, lift the hard-drive assembly off the computer base.
  19. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Disconnecting the Interposer: adım 19, 1 resimden 1.
    • Disconnect the interposer from the hard drive.
  20. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: adım 20, 1 resimden 1.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  21. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Bracket: adım 21, 2 resimden 1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Bracket: adım 21, 2 resimden 2.
    • Lift the hard-drive bracket off the hard drive.
  22. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard Drive: adım 22, 2 resimden 1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard Drive: adım 22, 2 resimden 2.
    • Place the NEW hard drive in the hard-drive bracket.
  23. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: adım 23, 1 resimden 1.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  24. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Connecting the Interposer: adım 24, 1 resimden 1.
    • Connect the interposer to the hard drive.
  25. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Align the Screw Holes: adım 25, 1 resimden 1.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  26. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Connecting the Interposer: adım 26, 1 resimden 1.
  27. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard-Drive Assembly: adım 27, 1 resimden 1.
    • Place the hard-drive assembly in the hard-drive bay.
  28. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Aligning the Screw Holes: adım 28, 1 resimden 1.
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  29. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: adım 29, 1 resimden 1.
    • Replace the screws that secure the hard-drive assembly to the computer base.
  30. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: adım 30, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions After Working Inside Your Computer.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  31. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Assembly: adım 31, 2 resimden 1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Assembly: adım 31, 2 resimden 2.
    • Using the pull-tab, gently lift the hard-drive assembly.
  32. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Latch: adım 32, 1 resimden 1.
    • Lift the latch and disconnect the hard-drive cable from the system board.
  33. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Assembly: adım 33, 1 resimden 1.
    • Lift the hard-drive assembly off the computer base.
  34. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Disconnecting the Interposer: adım 34, 1 resimden 1.
  35. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Remove the Screws: adım 35, 1 resimden 1.
  36. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Lifting the Hard-Drive Bracket: adım 36, 1 resimden 1.
  37. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard-Drive: adım 37, 2 resimden 1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard-Drive: adım 37, 2 resimden 2.
    • Place the NEW hard drive into the hard-drive bracket.
  38. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Align the Screw Holes: adım 38, 1 resimden 1.
  39. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: adım 39, 1 resimden 1.
  40. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Connect the Interposer: adım 40, 1 resimden 1.
    • Connect the interposer to the hard-drive.
  41. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Placing the Hard-Drive Assembly: adım 41, 1 resimden 1.
  42. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Aligning  the Screw Holes: adım 42, 1 resimden 1.
  43. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Replace the Screws: adım 43, 1 resimden 1.
  44. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Popping up the Memory Module: adım 44, 1 resimden 1.
    • Using your fingertips, carefully spread apart the securing clips at the sides of the memory-module connector until the memory module pops up.
  45. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Slide and Remove: adım 45, 2 resimden 1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Slide and Remove: adım 45, 2 resimden 2.
    • Slide and remove the memory module from the memory-module connector.
  46. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Align the Notch: adım 46, 2 resimden 1. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Align the Notch: adım 46, 2 resimden 2.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  47. Dell Alienware 17 Memory Modules 1 & 2 Replacement, Add new module: adım 47, 1 resimden 1.
    • Slide the memory module into the connect or at a 45-degree angle, and press the memory module down until it clicks in place.  If you do not hear the click, remove and reinstall the memory module
    • The computer may not boot if the memory module is not installed correctly.
Sonuç
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,224
