Ana içeriğe geç
Dell Alienware 18 Battery Pack Replacement
Neye ihtiyacın var
  1. Dell Alienware 18 Battery Pack Replacement, Before You Begin: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Battery Pack Replacement, Remove the base cover screws: adım 2, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Battery Pack Replacement, Slide the Cover: adım 3, 1 resimden 1.
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Battery Pack Replacement, Prelude: adım 4, 1 resimden 1.
  5. Dell Alienware 18 Battery Pack Replacement, Remove the battery screws: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two screws securing the battery to the computer base.
  6. Dell Alienware 18 Battery Pack Replacement, Disconnect the battery cable: adım 6, 1 resimden 1.
    • Disconnect the battery cable from its connector by pulling it straight up from its socket.
  7. Dell Alienware 18 Battery Pack Replacement, Remove the battery: adım 7, 1 resimden 1.
    • Remove the battery from its recess.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Bir başkası bu kılavuzu tamamladı.
darrius
5.213 İtibar
30 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
Bir Yorum
This is the wrong computer being displayed here.
Tru-B -DaT - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 17
Her zaman: 1,185
