Ana içeriğe geç
Dell Alienware 18 Coin-Cell Battery Replacement
Neye ihtiyacın var
  1. Dell Alienware 18 Coin-Cell Battery Replacement, Before You Begin: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Coin-Cell Battery Replacement, Remove the base cover screws: adım 2, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Coin-Cell Battery Replacement, Slide the Cover: adım 3, 1 resimden 1.
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery: adım 4, 1 resimden 1.
    • WARNING: The battery may explode if installed incorrectly. Replace the battery only with the same or equivalent type. Discard used batteries according to the manufacturer’s instructions.
    • CAUTION: Removing the coin-cell battery resets the BIOS settings to default. It is recommended that you note the BIOS settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from its connector on the system board.
  5. Dell Alienware 18 Coin-Cell Battery Replacement, Removing the Coin-Cell Battery: adım 5, 1 resimden 1.
    • Remove the coin-cell battery cable from the routing guides on the computer base.
  6. Dell Alienware 18 Coin-Cell Battery Replacement, Prying the Coin-Cell Battery: adım 6, 1 resimden 1.
    • Pry up the coin-cell battery from the slot on the system board.
  7. Dell Alienware 18 Coin-Cell Battery Replacement, Placing Coin-Cell Battery: adım 7, 1 resimden 1.
    • Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
  8. Dell Alienware 18 Coin-Cell Battery Replacement, Routing the Coin-Cell Battery Cable: adım 8, 1 resimden 1.
    • Route the coin-cell battery cable through the routing guides on the computer base.
  9. Dell Alienware 18 Coin-Cell Battery Replacement, Connecting Coin-Cell Battery: adım 9, 1 resimden 1.
    • Connect the coin-cell battery cable to its connector on the system board.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
darrius
5.213 İtibar
30 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 426
