Ana içeriğe geç
Dell Alienware M11x R3 2.5" Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: adım 1, 3 resimden 1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: adım 1, 3 resimden 2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: adım 1, 3 resimden 3.
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: adım 2, 1 resimden 1.
    • Remove the three screws attaching the hard drive tray to the laptop.
  3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: adım 3, 1 resimden 1.
    • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
  4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: adım 4, 2 resimden 1. Dell Alienware M11x R3  2.5" Hard Drive Replacement: adım 4, 2 resimden 2.
    • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
  5. Dell Alienware M11x R3  2.5" Hard Drive Replacement: adım 5, 2 resimden 1. Dell Alienware M11x R3  2.5" Hard Drive Replacement: adım 5, 2 resimden 2.
    • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
    • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Richard Maurice
534 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 UMass Dartmouth, Team S3-G7, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,577
