Ana içeriğe geç
Dell Alienware M11x R3 Battery Replacement
Neye ihtiyacın var
  1. Dell Alienware M11x R3 Battery Replacement, Lower Case: adım 1, 3 resimden 1. Dell Alienware M11x R3 Battery Replacement, Lower Case: adım 1, 3 resimden 2. Dell Alienware M11x R3 Battery Replacement, Lower Case: adım 1, 3 resimden 3.
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Battery Replacement, Battery: adım 2, 1 resimden 1.
    • Ensure your Dell Alienware M11x R3 is turned off and disconnected from any power source. Close the lid and flip the laptop over to access the bottom panel.
  3. Dell Alienware M11x R3 Battery Replacement: adım 3, 1 resimden 1.
    • Caution: Ensure computer is completely powered down before attempting to remove the lower case of the computer.
    • Close the lid and flip the laptop over to access the bottom panel. Unscrew the two circled screws.
  4. Dell Alienware M11x R3 Battery Replacement: adım 4, 1 resimden 1.
    • After removing the two screws, gently lift up the battery with the small plastic tab attached.
  5. Dell Alienware M11x R3 Battery Replacement: adım 5, 1 resimden 1.
    • Caution: Do not attempt to fully remove the battery while the wire is still connected.
    • Lift the battery out of its casing while allowing the wire to remain attached.
  6. Dell Alienware M11x R3 Battery Replacement: adım 6, 1 resimden 1.
    • Behind the battery, locate the PD12 battery wire and gently unplug it.
  7. Dell Alienware M11x R3 Battery Replacement: adım 7, 1 resimden 1.
    • With the wire unplugged, and all of the screws taken out, you are free to remove the battery for replacement.
    • Remember to properly dispose of the old battery according to local regulations and recycling guidelines.
Sonuç
To reassemble your device, follow these instructions in reverse order using a new battery in place of the old one.
2 farklı kişi bu kılavuzu tamamladı.
Richard Maurice
534 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 UMass Dartmouth, Team S3-G7, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 2,158
