Ana içeriğe geç
Dell Alienware M11x R3 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: adım 1, 3 resimden 1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: adım 1, 3 resimden 2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: adım 1, 3 resimden 3.
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: adım 2, 2 resimden 1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: adım 2, 2 resimden 2.
    • Your Wi-Fi card will have two coaxial cable wires connected to it.
    • Gently pull up the wires to disconnect them from the Wi-Fi card.
    • Be careful when you pull the wires. Pulling them hard or yanking them hard might cause damage to the wire or the Wi-Fi card.
  3. Dell Alienware M11x R3 Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Once the wires are removed, use an appropriate screwdriver to remove the screws holding down the Wi-Fi card.
  4. Dell Alienware M11x R3 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Dell Alienware M11x R3 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • When the Wi-Fi card pop ups, slide it out of the socket.
    • Any mishandling of the Wi-Fi card will cause serious damage to it, so please be careful with it.
Sonuç
Richard Maurice
534 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 UMass Dartmouth, Team S3-G7, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 695
