Ana içeriğe geç
Dell Alienware M17x R3 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Alienware M17x R3 Hard Drive Replacement, Loosen the Captive Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the three captive screws that se cure the hard-drive assembly to the computer base.
  2. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive: adım 2, 1 resimden 1.
    • Using the pull-tab, lift the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive Assembly: adım 3, 1 resimden 1.
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Alienware M17x R3 Hard Drive Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  5. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive: adım 5, 1 resimden 1.
    • Lift the hard-drive off the hard-drive bracket.
  6. Dell Alienware M17x R3 Hard Drive Replacement, Remove the Interposer: adım 6, 1 resimden 1.
    • Remove the interposer from the hard drive.
  7. Dell Alienware M17x R3 Hard Drive Replacement, Connecting the Interposer: adım 7, 1 resimden 1.
    • Connect the interposer to the NEW hard drive.
  8. Dell Alienware M17x R3 Hard Drive Replacement, Placing the Hard Drive: adım 8, 2 resimden 1. Dell Alienware M17x R3 Hard Drive Replacement, Placing the Hard Drive: adım 8, 2 resimden 2.
    • Place the hard drive in the hard-drive bracket.
  9. Dell Alienware M17x R3 Hard Drive Replacement, Replace the Screws: adım 9, 1 resimden 1.
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  10. Dell Alienware M17x R3 Hard Drive Replacement, Align the Connector: adım 10, 1 resimden 1.
    • Align the connector on the hard drive with the connector on the system board and press the hard drive until it is fully seated.
  11. Dell Alienware M17x R3 Hard Drive Replacement, Tighten the Screws: adım 11, 1 resimden 1.
    • Tighten the three captive screws that secure the hard-drive assembly to the computer base.
Sonuç
Terrence15
79.121 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,230
