Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Loosen the captive screws that secure the display cable to the system board.
Using the pull-tab, pull the display cable to disconnect the display cable from the connector on the system board.
Disconnect the camera cable and infrared cable from the respective system board connectors.
Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables from the routing guides on the palm rest assembly.
Remove the screws that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
Route the display cable, camera cable, infrared cable, wirelessHD card cable, and Mini-Card antenna cables through the routing guides on the palm rest assembly.
Connect the display cable to the connector on the system board.
Tighten the captive screws that secure the display cable to the system board.
Connect the camera cable and infrared cable to the respective system board connectors.
