Giriş
In this guide, we will show you how to remove and replace the Memory Modules.
Neye ihtiyacın var
Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Align the notch in the NEW memory module with the tab in the memory-module connector.
Slide the memory module into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
