Ana içeriğe geç
Dell Alienware M18x R2 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Alienware M18x R2 Display Assembly Replacement, Disconnecting the Video-Card Connector Cable: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Disconnect and peel off the video-card connector cable from the connectors on the system board.
  2. Dell Alienware M18x R2 Display Assembly Replacement, Pull the Pull-Tab: adım 2, 1 resimden 1.
    • Pull the pull-tab to disconnect the display cable from the connector on the system board.
  3. Dell Alienware M18x R2 Display Assembly Replacement, Disconnecting the LED Logo Board Cable: adım 3, 1 resimden 1.
    • Disconnect the LED-logo board cable from the connector on the system board.
  4. Dell Alienware M18x R2 Display Assembly Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Close the display and turn the computer over.
    • Remove the screws that secure the display assembly on the computer base.
  5. Dell Alienware M18x R2 Display Assembly Replacement, Note the Routing: adım 5, 1 resimden 1.
    • Disconnect the antenna cables from the connectors on the Mini-Card.
    • Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
    • Turn the computer over and open the display.
    • Note the routing of the display cable and LED-logo board cable, and then remove the cables from the routing guides on the palm-rest assembly.
  6. Dell Alienware M18x R2 Display Assembly Replacement, Remove the Screws: adım 7, 1 resimden 1.
    • Remove the screws, on the display hinges, that secure the display assembly to the computer base.
  7. Dell Alienware M18x R2 Display Assembly Replacement, Sliding the Antenna Cables: adım 8, 1 resimden 1.
    • Gently slide out the antenna cables through the slot on the computer base.
  8. Dell Alienware M18x R2 Display Assembly Replacement, Moving the Display: adım 9, 1 resimden 1.
    • Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
  9. Dell Alienware M18x R2 Display Assembly Replacement, Replace the Screws: adım 10, 1 resimden 1.
    • Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
    • Route the display cable and LED-logo board cable through the routing guides on the palm-rest assembly.
  10. Dell Alienware M18x R2 Display Assembly Replacement, Connecting the Display Cable: adım 12, 1 resimden 1.
    • Connect the display cable, video-card connector cable, and LED-logo board cable to the respective connectors on the system board.
  11. Dell Alienware M18x R2 Display Assembly Replacement, Sliding the Cables: adım 13, 1 resimden 1.
    • Slide the Mini-Card antenna cables through the slot on the computer base.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 1,262
