Ana içeriğe geç
Dell Axim X30 Screen Replacement
Neye ihtiyacın var
  1. Dell Axim X30 Screen Replacement, Screen: adım 1, 3 resimden 1. Dell Axim X30 Screen Replacement, Screen: adım 1, 3 resimden 2. Dell Axim X30 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Remove the four rubber feet with your fingers.
  2. Dell Axim X30 Screen Replacement: adım 2, 2 resimden 1. Dell Axim X30 Screen Replacement: adım 2, 2 resimden 2.
    • Trigger battery release by inserting a nylon spudger into the battery release tab.
    • Slide tab and pull upwards on the battery to remove. Use the finger slots near the battery.
  3. Dell Axim X30 Screen Replacement: adım 3, 1 resimden 1.
    • Remove the four 12.7mm screws under rubber feet with a JIS #0 screwdriver.
  4. Dell Axim X30 Screen Replacement: adım 4, 1 resimden 1.
    • Remove back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
    • The back panel should just pop off.
  5. Dell Axim X30 Screen Replacement: adım 5, 3 resimden 1. Dell Axim X30 Screen Replacement: adım 5, 3 resimden 2. Dell Axim X30 Screen Replacement: adım 5, 3 resimden 3.
    • Disconnect ribbon cables.
    • You may need to use a little force to disconnect them.
    • Disconnect red and white wired connector for speaker and motherboard battery.
  6. Dell Axim X30 Screen Replacement: adım 6, 2 resimden 1. Dell Axim X30 Screen Replacement: adım 6, 2 resimden 2.
    • Remove three 12.7mm JIS #0 screws.
  7. Dell Axim X30 Screen Replacement: adım 7, 1 resimden 1.
    • Carefully remove motherboard.
  8. Dell Axim X30 Screen Replacement: adım 8, 2 resimden 1. Dell Axim X30 Screen Replacement: adım 8, 2 resimden 2.
    • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
  9. Dell Axim X30 Screen Replacement: adım 9, 2 resimden 1. Dell Axim X30 Screen Replacement: adım 9, 2 resimden 2.
    • Remove black plastic board.
  10. Dell Axim X30 Screen Replacement: adım 10, 2 resimden 1. Dell Axim X30 Screen Replacement: adım 10, 2 resimden 2.
    • Gently apply pressure on the right plastic frame by plastic clip marked on the picture.
    • Apply pressure to the bottom of the screen and press it towards you.
    • Remove screen from plastic case.
Sonuç
Peter Reilly
196 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G5, Harley Spring 2018 IUPUI, Team S2-G5, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S2G5
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 777
