Ana içeriğe geç
Dell Chromebook 11 3180 Touchpad Replacement
Neye ihtiyacın var
  1. Dell Chromebook 11 3180 Touchpad Replacement, Back Cover: adım 1, 1 resimden 1.
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Touchpad Replacement: adım 2, 1 resimden 1.
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Touchpad Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Touchpad Replacement: adım 4, 1 resimden 1.
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Touchpad Replacement: adım 5, 1 resimden 1.
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Touchpad Replacement, Battery: adım 6, 2 resimden 1. Dell Chromebook 11 3180 Touchpad Replacement, Battery: adım 6, 2 resimden 2.
    • Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
    • You can locate this cable by checking that its other end connects to the battery. It has black protective wrap.
  7. Dell Chromebook 11 3180 Touchpad Replacement: adım 7, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
  8. Dell Chromebook 11 3180 Touchpad Replacement: adım 8, 1 resimden 1.
    • Lift the battery away from the computer to remove it.
    • If there is any resistance to the battery being removed, make sure that all of the screws have been properly removed and that nothing is blocking the battery.
  9. Dell Chromebook 11 3180 Touchpad Replacement, Touchpad: adım 9, 2 resimden 1. Dell Chromebook 11 3180 Touchpad Replacement, Touchpad: adım 9, 2 resimden 2.
    • Unplug the touch pad from itself by lifting up on the connector and pull out the ribbon cable.
  10. Dell Chromebook 11 3180 Touchpad Replacement: adım 10, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the five 2mm and single 3mm screws. Set the screws aside and note that they are for the touch pad.
    • One screw will be slightly smaller in size than the other five.
  11. Dell Chromebook 11 3180 Touchpad Replacement: adım 11, 1 resimden 1.
    • Lift the touch pad, with it's bracket, away from the computer to remove it.
Sonuç
Devon Paul
1.206 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G1, Livingston Spring 2017 Cal Poly, Team S22-G1, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 2,054
