Giriş
In this guide, we will show you how to remove and replace the Display Assembly.
Neye ihtiyacın var
Remove the display hinge screws M2.0xM5.0 that secure the display assembly to the computer.
Place the display assembly to align with the screw holders on the computer.
Replace the screws that secure the display hinges to the palm-rest assembly.
Flip over the computer and connect the sensor cable on the system board.
Connect the display cable to the connector on the system board.
Place the metal bracket over the (display cable) connector, and tighten the M2.0x3.0 screws to secure the display cable to the computer.
Place the metal bracket, and tighten the M2.0x3.0 screw to the WLAN cable on the system board.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Hola, he remplazado la pantalla. El montaje perfecto pero no enciende. Hay que hacer algo en concreto? Me refiero para que detecte esta pantalla nueva.
Muchas gracias
